Thread: Report generator
    Default Report generator
    We need to make some reports for our customer. In one of these reports we need to present a sum of the amount of starts on a unit. The period should be selectable using the time filter. Also we need to show a cummulative of the amount of time.
    How can we do this with the Report Generator ?
    Best Regards,
    Stephan de Wit
    Default Re: Report generator
    Take a look at the mathematics driver. In the formula for the value calculation you will find the category statistics.
    Here you can configure a counter COUNT(X01)
    X01 would be the boolean variable representing the unit state. After configuring the formula, you will see a dialog where you can select this counter to be an operations counter (on limit value 1) or where you can select this counter to be an operation hours counter (count in seconds, minutes, hours, days)
    You can then display the mathematics variables values in a screen, store them in an archive or use the variable values in a report.
    The values of the counters are saved to the disk when closing the runtime, or you can implement a cyclic saving of the values by using the function "save remanent data" or the "cel / aml save ringbuffer"
    You can find more information in the mathematics driver documentation.
  1. Format of SQL query results in Report Generator
    Last Post: 13th August 2010, 16:08
  2. i-bit in report
    By roberto1978 in forum zenon Supervisor
    Last Post: 12th May 2010, 14:22
  3. basic mathematics in report generator
    Last Post: 5th March 2010, 08:40
  4. Handling Asynchronous Data - Report Generator
    By mike.edkins in forum Drivers
    Last Post: 3rd February 2010, 13:35
  5. Report Generator
    By rolindo in forum zenon Supervisor
    Last Post: 21st November 2009, 23:50
