Thread: Filter Cel results in certain intervals
    28.03.2011
    25
    Ausrufezeichen Filter Cel results in certain intervals
    Hi guys, I'm working on a project, I'm measuring two values, and I need to print them at 8am, 4pm and 12 o'clock every day.
    How can I set up the filter for this task?
    Urgent!
    Default Re: Filter Cel results in certain intervals
    if you just want to print a few values at certain intervals, probably the zenon standard function "print current values" (in the variables section) is just the thing you need!
    Using a format file, you can specify which variable values to print, and you can add a date and time, including a header and footer with plain text
    28.03.2011
    25
    thank you for your fast reply, I tried that, but I need an automated printout at those times...
    I would also need to print those results in a table, not as a listing, if you could help me with that, it would the great!
    You can use "time control" to execute a zenon standard function at regular intervals. This could be the "print current values", but could also be the print report function.
    The reports in the report generator are one other way to print values. Here you can also include CEL entries, alarm entries etc. and apply formatting in a table.
    The report generator is an optional module that requires a license in the editor, and in the runtime when writing values or changing archived data from the historian.
  1. Alarm filter VSTA
    By dvangenderen in forum VSTA
    Last Post: 25th October 2010, 15:03
  2. CEL Filter
    By hicom in forum zenon Service Engine Supervisor
    Last Post: 24th August 2010, 11:51
  3. Format of SQL query results in Report Generator
    By affoltep in forum zenon Service Engine Supervisor
    Last Post: 13th August 2010, 16:08
  4. flash-filter in the editor
    Last Post: 16th October 2007, 15:58
