Thread: Reading Modbus variable that contains multiple words
    26.11.2009
    59
    Default Reading Modbus variable that contains multiple words
    hi,
    I need to read the Fault recorder value from Areva P122 device with Modbus RTU protocol by zenon. This device has 5 fault recorders and modbus address to upload them are as below:
    3700h Fault 1
    3701h Fault 2
    3704h Fault 5
    each of them contains 15 words according attached file. Also there is instruction for reading them by manufacture.
    How do I apply manufacture instruction for reading my desire data from device with Modbus protocol by zenon?
    The version of zenon is 6.51 SP0.
    Thanks in advance
    Attached Thumbnails Attached Thumbnails selected pages.pdf   P12x_enct_f75.pdf
    Default Re: Reading Modbus variable that contains multiple words
    Have you found a solution for this?
    The modbus energy driver does support reading event data from Areva devices from the type MiCOM P126 / P127, but I'm not sure if the P122 also supports the functionality available in the P126 / P127.
    26.11.2009
    59
    Hi mark
    I tested all of data types that supports by zenon and also RGM but it seems that there is no solution for it.
    I think my problem is one of below items:
    1.I cannot define a new tag that includes 15 words with one address point (only for first word)
    2.I cannot access to structure of modbus message in zenon for defining it and send to device
    I don’t use from modbus energy driver because it needs IP connection and also is not easy. I think the reading Holding register is easy and does not needs VBA.
    The difference between P122 and P126/P127 are in their protections functionality so their Modbus modules are same.
  1. Real Variable Modbus TCP
    By pkreisel in forum Drivers
    Last Post: 15th February 2011, 23:39
  2. 64bit data type in modbus
    Last Post: 12th January 2011, 14:01
  3. Modbus read input status
    By maurodx in forum Drivers
    Last Post: 2nd September 2009, 00:21
  4. Replies: 1
