Thread: Process Gateway module in demo license
    michael_k Gast
    Default Process Gateway module in demo license
    I want to evaluate the Process Gateway module (IEC60870 slave).
    My development station has not its license currently and is there any way to access it in demo license?
    105
    Default Re: Process Gateway module in demo license
    You can use the IEC60870 gateway in domomode. Just use the DEMO licence.
    If you allready have an other licence, you can switch to the DEMO licence in the zenon6.ini file.
    You find this file by entering %CD_SYSTEM% in the Explorer.
    The DEMO licence should be in there, with semicollons ';' in front to comment it out.
    Markus
    michael_k Gast
    I could access to demo standard or demo energy edition but my problem is the activation of IEC60870 gateway module.
    My questions are:
    First: dose demo license (standard or energy) has IEC60870 gateway module?
    Second: if yes , how can I access it?
    Also be inform that I do according to the manual of process gateway as below:
    1. Active the DLL=AccessIEC870Sl.DLL and project name in zenProcGateway.ini file
    2. Run RT then active the zenProcGateway.exe but below message appear:
    “Required protocol module not licensed!”
    and when click the previous message this message appears :
    “Communication of ‘AccessIEC870SL.DLL’ cannot be initialized!
    Please check configuration”
    thanks
    michael_k Gast
    i use from 6.51 SP0.
    michael_k Gast
    I could activate it successfully, there were some mistakes.
    thankyou
    22.06.2017
    2
    Which mistakes?
    I have the same Problem.
  1. Process Gateway
    By murphys in forum Drivers
  2. Zenon process gateway.
    Last Post: 14th January 2010, 13:17
  3. DNP- Process Gateway
  4. Process Gateway
  5. Replies: 0
