Thread: RGM info
    Default RGM info
    i need to know the name or number of the recipe group select in the combo box.
    how can i do this????? what is the correct syntax in vba???
    (see attach file)
    881
    Default Re: RGM info
    Check out this thread: http://www.copadata.com/forums/showthread.php?t=216
    see attach file where i insert the script use in the module element (leftclickdown) associated with COMBOBOX "Elemento di controllo_30". how can i execute it in runtime when i change the recipe grupe in the combobox??? Help me please.
    Although this won't help you right now, a development for the next zenon release is scheduled, to have status variables that show which recipe group, recipe, recipe version and recipe status, is currently selected in the screen.
