Thread: language for ZenonCERT
    yara Gast
    Default language for ZenonCERT
    I have ZenonCERT runing on widows CE devise, the problem that in CEL pic for example showing the description on germany langauge and i wont to change it to show in english.
    Means that i have germany language at run time and i wont to change it to english language.
    Thanks in advance
    Default Re: language for ZenonCERT
    It seems you have received a CE terminal where the zenon CE runtime was installed with the German language.
    To use English instead, you need the reenglice.dll file on your device (in addition to the rgermace.dll for German). Not always are all languages installed.
    When you do have this file on your device, you can open the file "zenon6.ini" on the device with a text editor, and at the setting "LANGUAGE=" change from GERMAN to ENGLISH.
    If you don't have this file, you need the zenon CE installation CD for your respective zenon Version and Servicepack, to install the zenon CE runtime files on your PC, in order to be able to install it in English on your CE terminal
    yara Gast
    Thank you i will try it.
  1. Change Language with user login
    Last Post: 23rd April 2010, 10:03
  2. Chinese language on CE devices
    Last Post: 13th April 2010, 23:50
  3. zenOn 6.50 paralel installation with 6.21/6.22 - language problem
    By micko in forum Editor and Runtime Setup
    Last Post: 24th March 2010, 11:13
  4. the filters is displayed in other language
    Last Post: 26th April 2009, 10:33
  5. Language Table Keywords and VBA
    By jhines in forum VBA
    Last Post: 18th September 2008, 14:52
