Thread: how to change text and color of invisible button
    14.12.2010
    25
    Default how to change text and color of invisible button
    hi
    I need to know that how to change invisible button text fount . At runtime text is show on Embedded symbol and second think is it possible that we change it into separate button
    Screen shots is attached that clear my question
    Best regards
    Default Re: how to change text and color of invisible button
    You can change the font for the control element "object list for zooming" that shows the stations for the worldview control screen.
    Just select the element in the screen in the editor that shows the stations in the runtime, and link a different size font in the properties window. Also you can change the color for the font in the properties window for this element.
    To answer your second question, you can pre-set the zoom center, and the zoom level, by using the zenon function "screen: move center".
    At this function you can either specify a station or coordinates and additionally define the zoom level.
  1. Replies: 3
    Last Post: 1st May 2013, 21:31
  2. Dynamic color ir Button
    By softart2 in forum zenon Supervisor
    Last Post: 13th September 2010, 11:50
  3. CEL- text color
    Last Post: 21st December 2009, 11:38
  4. Change Text Button with DynProperties
    By acko01 in forum VBA
    Last Post: 16th October 2009, 10:29
  5. Option button background color wrong
    By russelldrown in forum VBA
    Last Post: 5th May 2009, 12:51
