Thread: Search Variables & linked Objects
    derda Gast
    Default Search Variables & linked Objects
    Hello together,
    in my Projekt( zen0n 6.51) i can search "right click on every objekt" to the linked objekts. For examples one variable use datatype "Bool" and the TCP/IP-Driver. Nice to know...
    But: I want to see every objekt that use this variable! I will delete this one, but i donīt know where the variable is used.
    Thank you for your efforts!
    Default Re: Search Variables & linked Objects
    Please have a look at the cross reference list in the zenon editor. This will allow you to search where variables / functions are directly used.
    Please note however, that this search does not include places where variables can be indirectly used, and also does not show if this variable is used in other projects. Indirect variable usage can include the programming interface and externa applications, dynamically created variable links at linked symbols and screen switch functions with replace links and replace indices.
    It is recommended to create a backup before deleting unused variables / functions.
  1. search replace variable text
    By joulz in forum zenon Supervisor
    Last Post: 5th October 2009, 10:29
  2. Global search and replace
    Last Post: 26th November 2008, 08:29
  3. Working with 'DynPicture' objects
    By robertf in forum VBA
    Last Post: 16th August 2007, 09:24
  4. Working with the 'Alarm' objects
    Last Post: 16th August 2007, 09:22
  5. Working with the 'CEL' objects
    Last Post: 16th August 2007, 09:20
