Thread: time filter of report for following archive
    26.11.2009
    59
    Default time filter of report for following archive
    I made an archive for ETM with 1min cycling scan and defined one day as Archive saving cycle, so it gave 1440 points per day for each variable and all of them in one file. Then I activated “New following archive” for calculating Maximum value of per day for previous data. My goal is creating monthly maximum data report. The new archive gives one point per day for each variable and I use its data for report. The report screen and its time filter have been designed for one month.
    The monthly maximum data report works correctly in RT but on the other side, there is limitation in selecting day because you can choose only year and month in its time filter. The report shows since 1st to current day for
    each month that you have been selected.
    This is correct only for current month and not for previous months. I attached its screen shot as attachment.
    the Zenon version is 6.22 SP1.
    Is there any way for beginning report for previous months from 1st to end of month?
    thanks
    26.11.2009
    59
    Default Re: time filter of report for following archive
    Could anybody have comment for me in above case?
    thanks in advance
    Default AW: time filter of report for following archive
    Attached you will find a project to demonstrate how to set up the archives and filters to display the correct values in an report.
    Take look at
    Function: Report_Month; Tab 'Time': Properties: Offset and Length
    Report: Month.xrs; Cell: D4; function 'archivem() is used to modify the time that should be displayed.
    Extract the file ARCHIV_REPORT.zip into the runtime directory to see ready-made archives.
    Can you please post the file for "2011-01-01_11-01-31 archiv_report.zip" again? The link does not work anymore.
  1. problem with archive values in report
    By shahramkh59 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 20th October 2009, 13:40
  2. Setup a filter at design time
    By matholton in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 3rd October 2008, 08:40
  3. compare time variable with system time
    By flajoso in forum VBA
  4. How to have cumulative alarms time in report
    By fabios in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 21st May 2008, 10:08
