Thread: Usage of CD_DotNetControlContainer
    23.11.2009
    22
    Default Usage of CD_DotNetControlContainer
    I need some help for understanding how to iteract with a .net control hosted in a CD_DotNetControlContainer (activeX element).
    There is some sample in the documentation?
    I'm stuck on this code and I don't know how to proceed...
     IDynPicture picture = this.DynPictures().Item("img_Test");
      IElement control = picture.Elements().Item("ActiveX_1");
      object a = control.AktiveX();
    It's possible to access methods, properties and events of the hosted control?
    28.07.2008
    64
    Default Re: Usage of CD_DotNetControlContainer
    maybe this could be helpful
    sph11 Gast
    i have created a Control but i have the problemt that when i add it to Zenon i gets
    a small Border with an almost purple color.
    What can i do to get it away? Or how can i change it?
    Btw, we have same issue with BackColor of UserControl - after insert UserControl it has RGB(FFE4C4) color. As temporary solution we change BackColor to any other color and then restore Contol color - it helps to return base UserControl BackColor.
    It reminds me the Blue ControlText in GroupBox ForeColor in VS2008, that after similar actions transforms into Black ControlText...
    After first opening zenon window with CD_DotNetControlContainer placed on it in runtime, linked dll-file becomes non-writeable.
    Is there an ability to update dll-file without close and then open runtime project?
