Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 11
Thread: Tooltips
    Default Tooltips
    Is it possible to have variable content displayed in a tooltip for a button/Combi element ? In our case we have a string variable which we would like to display in the tooltip of an element.
    Stephan de Wit
    Default Re: Tooltips
    Unfortunately, this is currently not possible.
    However a requirement to implement this in a future version already exists.
    Will this feature be implemented in before-seven version of zenon?
    Or maybe somebody knows any walk-around way to use such dynamic-tooltip in 6.51-version of zenon?
    To avoid disappointment, I just want to clarify that "to be implemented in a future version", does not necessarily mean that this feature will be included in the next zenon version 7.
    The fact that a requirement exists means that we think this is a good idea and we intend do implement this in a future version, which not necessarily must be the next zenon version that is released.
    25.05.2010
    Dallas, TX
    7
    We had the same need, and I found a workaround. See the attached project.
    How do the native tooltips work?
    In the zenon runtime, there always exists one (and only one) subclassed window (see attachment, spy.png) which is used to show tooltips over elements that have a tooltip assigned in the editor. Trust me, you do not want to try to force this tooltip to show your custom tooltips.
    How do the tooltips in the attached project work?
    In the VSTA ProjectAddin namespace, I have added a form (frmTooltip), with the "Opacity" property set to 1% (practically invisible.) One instance of the form is constructed at the "ProjectActive" event. At the "ElementMouseOver" event (provided by the DynPictures object at runtime), the form is moved to the location of the element, sized the same as the element and brought to the front. Finally the tooltip is set, if the value in the string variable has a length greater than zero. On the "MouseLeave" event of the form, the tooltip is set to an empty string and the form is hidden.
    I banged my head against the wall for a long time trying to use the existing hidden window in zenon. Finally, I realized the .NET solution was much simpler.
    Here's hoping someone finds this useful!
    882
    Default AW: Tooltips
    nice
    25.05.2010
    Dallas, TX
    7
    Image (spy.png) is now attached.
    Quote Originally Posted by tsragland View Post
    Daumen hoch Re: Tooltips
    Thanks tsragland!
    that is awesome
    And this way, the "tooltip" even supports more than 80 characters
    note, that you do need a later build of zenon 6.51, or zenon 7, that includes screen events in VSTA, in case you want to try out the sample project
    Cheers,
    25.05.2010
    Dallas, TX
    7
    I noticed the tooltip form was being activated and stealing focus from other windows, so I made a small change to the implementation:
    We need to show the tooltip form without activating it, so we can use the API method, 'ShowWindow' with the SW_SHOWNA parameter, which will show the form and bring it to the front without stealing focus from other windows.
    Add the following 'using' statement (this supports the DLLImport required to reference the Windows API function):
    using System.Runtime.InteropServices;
    Add the following method declaration (anywhere inside the 'frmTooltip' class):
    private const int SW_SHOWNA = 8;
            [DllImport("user32", CharSet = CharSet.Auto)]
            private extern static int ShowWindow(IntPtr hWnd, int nCmdShow);
    Replace the 'Set' method with the following code, which calls the API method, 'ShowWindow'
    public void Set(IElement obElement, string toolTipText)
                bool allowTooltip = true;
                try
                    IVariable v = obElement.ItemVariable(0);
                    if (v != null)
                        if (v.Name == "toolTipVariable")
                            allowTooltip = false;   //Don't show tooltip over an element linked to the string variable which contains the tooltip text!
                        v = null;
                catch { }
                if (allowTooltip)
                    try
                        if (toolTipText.Length > 0)
                            ShowWindow(this.Handle, SW_SHOWNA);
                            this.Left = obElement.Left;
                            this.Top = obElement.Top;
                            this.Width = obElement.Right - obElement.Left;
                            this.Height = obElement.Bottom - obElement.Top;
                            this.toolTip1.SetToolTip(this, toolTipText);
                    catch (Exception ex)
                        Debug.Print(ex.Message + ex.StackTrace);
    Now, the tooltip works without stealing focus from other zenon windows...
    29.11.2013
    4
    Unglücklich Re: Tooltips
    Hello!
    This functionality will be in this year? I want simply to add tooltips without programming. Maybe already it is time to add this functionality in Zenon? Passed three years...
