Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 13
Thread: Read with main project (scada) variable form CE project
    30.09.2010
    14
    Default Read with main project (scada) variable form CE project
    I have a scade project with two CE projects. The CE projects contains a beckhoff NG plc driver. The projects are linked with ethernet.
    Now I will read in Scada project with VSTA variables from the CE projects. Is it possible? So yes how?
    Thanks,
    DvG
    28.07.2008
    64
    Default Re: Read with main project (scada) variable form CE project
    VSTA can't be used directly on CE.
    You have two possibilities:
    1. Without VSTA ->You can directly link your Variable from the CE Project directly to a Element to your Top-Project provided that your CE Project is under the Top-Project node.
    2. With VSTA-> You must set your Variable DDE active than you can read/ write it from your Top Project (normal PC) directly like this way:
    public void Macro_GetVariableFromCE_Project()
                try
                    this.Variables().Item("Top_Project").set_Value(0,
     this.Parent.Parent.Projects().Item("CE_Project").Variables().Item("Var_02").get_Value(0));
                catch (Exception ex)
                    System.Diagnostics.Debug.Print("ERROR  " + ex.Message + " " + ex.Source);
    30.09.2010
    14
    I have in CE project the internal variable set to DDE Active.
    By methode 1 when this variable is linked to a element, is in the right corner a blue field and by right click the text NO UPDATE.
    Methode 2 gives de value -2147483638
    Is this a problem in nework topology/ routing?
    28.07.2008
    64
    You must set in your CE Project properties the CE Project as Network active and as server . Did you?
    30.09.2010
    14
    The property network active = yes.
    The name from the panel is set as sever from the CE project. This is the same place as the runtime folder.
    28.07.2008
    64
    Blue rectangel ona number element means you have no network connection.
    Does the RT runing on your PC and even on your CE-Pannel?
    Is the PC connected to the CE-Pannel?-> Try do ping the CE-Pannel from your PC.
    30.09.2010
    14
    Lächeln Re: Read with main project (scada) variable form CE project
    Thanks!!!!!!
    But I must first by Network topology -> select right server -> Transfer runtime files.... else make the scada project no link to the variabele.
    Would it be a problem if you set all your variables to DDE active ? Currently we have about 14000 variables. Or doesn't this matter at all ?
    881
    Setting all 14000 variables to DDE active would advise all of them at the driver(s). Thus all variables would be requested from the PLC (according to the cycle time of the PLC). Usually the zenon runtime itself nor the driver would be the bottleneck - it would be the PLC itself.
    Also it does not make sense to create an online container with all 14000 variables and starting the online container when starting the runtime.
    However, it is recommended to implement a dynamic online container. This means when variables should be read via the COM-Interface those variables should be defined in a online container and afterwards starting this online container (with .Define). After the variable values have been read the online container should be stopped again (with .Undefine).
    Note: you can easily check if a variable is available for reading its value with the method .IsOnline()
    -> if this method returns true you can read the value of the variable
    881
    ok.. i missed the point that this is a CE-Device....
    -> of course online containers are no option then because the COM-Interface is not available on CE-Devices...
  1. VSTA read variable value's another project!
    By dvangenderen in forum VSTA
    Last Post: 1st December 2011, 10:04
  2. Replies: 4
    Last Post: 21st June 2010, 07:12
  3. how can be save the project that consist of the sub project?
    By michael_k in forum zenon Service Engine Supervisor
  4. s7 project import
    By gh_ounie in forum Drivers
    Last Post: 27th October 2008, 12:59
