Thread: How to access to IEC 60870 IOA adress in Runtime
    28.08.2009
    26
    Default How to access to IEC 60870 IOA adress in Runtime
    Hi AlI
    How to Access to Driver Variable IEC60870IOA Address in runtime and get it as string ?
    I want to show it. For Example
    Circuit Breaker Position (2000) where 2000 is IEC 60870-101 Object address.
    is it possible?
    Default Re: How to access to IEC 60870 IOA adress in Runtime
    as far as I know, this is not possible
    The dynproperties for the Variable that can be used to set the object address in the editor, are not available in the runtime. (Debug.Print myVar.DynProperties("IEC870_IOA1"))
    Also the variable diagnosis screen does not show the extended addressing properties, like the sector, ASDU type and object address, in the "address" column.
  1. Access properties in symbols
    By antoniazzi in forum VBA
    Last Post: 10th August 2010, 23:33
  2. IEC 60870-5-101_104 startup
    By lunzer in forum zenon Energy Edition
    Last Post: 21st April 2010, 14:47
  3. Access to operating system
    Last Post: 13th January 2010, 05:22
  4. Access to Alarm Classes
    By olga in forum VBA
    Last Post: 12th January 2010, 00:15
  5. VBA and Microsoft Access
    By bjoerndavid in forum VBA
    Last Post: 30th November 2007, 22:22
