Thread: IEC61850 Driverconfiguration messed up after adding a driver
    Default IEC61850 Driverconfiguration messed up after adding a driver
    I added a IEC61870 driver to my project in which already a IEC60850 existed. After creating the driver and acknowledging the driver configuration, the configuration of the IEC60850 driver was messed up. Why is that?
    As with many other drivers, the configuration is stored in a file. The filename for most drivers has the default name "default.tcp". As both the IEC60850 and the IEC61870 are writing in the same file, the driver configuration gets corrupted. You should create for each driver in the project at creation it's own driver configuration file.
    765
    Default Re: IEC61850 Driverconfiguration messed up after adding a driver
    since few zenon versions the drivers are using unique file names. You may account this issue only projects converted from an old version. Most drivers have now the name of the configuration file (typically txt-file) configurable on 'basic settings' tab.
