Thread: Backfilling alarms
    Default Backfilling alarms
    We would like to know if there is any way to use backfilling with zenon. After connection failure we want to fill in the alarms that occured during this communication failure.
    Stephan de Wit
    Default Re: Backfilling alarms
    It depends a bit on what you're after. Do you want to have alarms (with a alarm comes / alarm goes time that is in the past) in the alarm list? Or are you OK with entries in the event list?
    With specific drivers, and functionality provided in the hardware, zenon does generate alarms for changes which have occurred while there is a communication interruption. For this the driver must support external timestamping, and the hardware must allow for buffering of values while there is no connection.
    It is not possible to write or modify an alarm entry through the programming interface, like it is possible to write entries in the event list.
  1. number of alarms
    Last Post: 25th June 2009, 05:33
  2. How to Stop Logging Alarms
    Last Post: 29th September 2008, 11:24
  3. Cumulative export of alarms.
    By nsko in forum zenon Supervisor
    Last Post: 4th September 2008, 12:38
  4. VBA scripts by alarms events
    By captain in forum VBA
    Last Post: 14th August 2008, 09:30
  5. Circular Alarms/Events
    By consol in forum zenon Supervisor
    Last Post: 13th August 2008, 10:11
