Thread: Problem of VSTA after restore project
    Default Problem of VSTA after restore project
    I created backup my tests project. After it I had tried to restore it on another PC with new name. All VSTA macros and events didn't work. If I had restored this project with old name macros and event worked good.
    What is the reason this problem?
    Default Re: Problem of VSTA after restore project
    this is a known issue (in version 6.50) and is allready fixed in the new version (version 6.51).
    To fix it, copy the GUID of the new project first (59a59c4c-3c34-44a9-b870-d73977723d90 in my case):
    then open the VSTA editor and in the project explorer select the "Show all files" view:
    then you have to exchange the old GUID in the two files ThisProject.designer.xml and ThisProject.designer.cs with the GUID of the new project:
    After doing this it should work.
    Thank you.
  1. SQL problem with zenOn 6.21 - huge project-log file
  2. Restore project from SQL Database Folder
    By bernhardf in forum zenon Supervisor
    Last Post: 13th October 2009, 09:07
  3. SQL problem with zenOn - huge project-log file
    Last Post: 16th April 2009, 07:07
  4. Could not restore backup in the editor
    By jegloco in forum zenon Supervisor
    Last Post: 2nd February 2009, 10:49
  5. Project manager problem.....
    By paf in forum zenon Supervisor
    Last Post: 21st April 2008, 13:44
