Thread: how open vipwin from visual basic?
    draganchem Gast
    Default how open vipwin from visual basic?
    I want to open some vipwin project from visual basic and start it. How can I do that?
    879
    Default Re: how open vipwin from visual basic?
    If you want that an external Visual Basic application (like VB6, Visual Basic 2005,.... ) should establish a connection to a already running runtime it would look something like this:
    Dim obAppRT As zenOn.Application
    Dim WithEvents obProjectRT As zenOn.Project
    Sub checkConnectionZenOn()
        On Error GoTo errorhandler
        'set Application object (zenOn Runtime)...
        If obAppRT Is Nothing Then
            Set obAppRT = GetObject(, "zenOn.Application")
        End If
        Debug.Print ("Connected to zenOn Runtime")
        'set Project object (first in list or defined by name)...
        Set obProjectRT = obAppRT.Projects.Item(0) 'first project in list...
        'Debug.Print obProjectRT.Name
        'set Project object (by name) ...
        'Set obProjectRT = obAppRT.Projects.Item("MYTESTS")
        If obProjectRT Is Nothing Then
            Debug.Print ("Project is not reachable!")
            Exit Sub
        End If
        Debug.Print ("Project available: " & obProjectRT.Name)
        If obProjectRT.Variables.Count = 0 Then
            Debug.Print ("No Variables within the Project!")
            Exit Sub
        End If
        Debug.Print ("Variables are available")
    errorhandler:
        If Err.Number <> 0 Then
            If (Err.Number = 429 Or obAppRT Is Nothing) Then
                '-->"Error creating ActiveX-control
                Debug.Print ("zenOn Runtime is not reachable!")
                Err.Clear
            Else
                Debug.Print (Err.Number & " " & Err.Description)
            End If
        End If
    Note: you have to insert the zenon32.tlb to the references
    If you simply want to start the runtime via VB6 you would have to execute the process zenrt32.exe
    By douglasm in forum VSTA
  2. basic mathematics in report generator
    Last Post: 5th March 2010, 08:40
  3. Name of curretly open picture
    By scotttee in forum VBA
    Last Post: 4th January 2010, 23:58
  4. Open database error
    By jan1024 in forum zenon Supervisor
    Last Post: 30th November 2009, 16:11
  5. display last open picture
    By dak2483 in forum zenon Operator
    Last Post: 5th September 2008, 18:57
