We are faced with the problem of reading Archived Trends . The system takes too much time and resources to read trends from a certain archive
The following readings are observed
a 5 days relative interval of 4 archived values the system would take about 4 seconds
a 10 days relative interval of the same 4 archived values the system would take about 15 seconds
the problem is significant when the interval is higher than 20 days for example
a 30 days relative interval of the same 4 archived values would take more than 5 minutes and sometimes halt the system for a long time ,where a forced system shutdown would be the only remedy.
And the required archive reading is at least 1 year. so imagine the time needed for reading values at such an interval.
note that when reading a 30 days interval we observed that the process zenonrt.exe process would consume a memory more than 1.7Gb
The PC is a Core 2 Duo 2.53 with 2 Gb of RAM
The Zenon Version is 6.22 SP0 build0 upgraded to Build6
The archive has a scan rate of 10 seconds and saved every 15 min in the default arx format
Is there a remedy for such a problem?
Best Regards.
