Thread: Error log in server application event.
    Default Error log in server application event.
    Hi guys
    Could you please see picture and give me some advise why I have some error log in window application event view? I do not know why is it?
    Best regards.
    Default Re: Error log in server application event.
    Hi guys
    The software is zenon 6.22 SP1 and window server 2003 SP2.
    The error display in window event viewer / application but the runtime seem still work fine.
    Please help.
    Best regards.
    what happend at that time on the computer, ran it anyhow under heavy load?
    Was a certain process producing a heavy CPU load.
    Such message, Log queue full, old messages lost, can also appear if the diagnosis server ( zensyssrv.exe) gets to many messages sent as it can handle.
    There is for e.g. a DEEBDEBUG set for a certain or all modules which would produce an enormous amount of log messages. Such deep loggings should only be used for investigations and must be turned of in normal working conditions.
    Use the Diagnosis Viewer to set it back to a normal level.
    Hi
    Thanks for your repply, now the error log did not happened again.
    But could you explain for me that why I tried to re-install window server 2003, re-install zenon, it happened. Is it sync from another server. I have two redundance server.
    Thanks and regards
    the settings for the logging for different processes which can be configured in the diagnosis viewer, is stored in the file "zenon6.ini". At uninstalling zenon this file is not removed, and reinstalling zenon will use the same settings for logging. (and e.g. also for the license information)
    This file however is not synchronized with a redundant server, and this way after formatting the harddrive and re-installing zenon (you would also need to enter the license information again) the logging is set back to default.
  1. SQL error when I try the archive server function
    By lephis in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 23rd April 2009, 14:20
  2. Log changes into cronologic event list (CEL)
    By hicom in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 8th April 2009, 07:22
  3. Access New CEL item event from VBA
    By karimsaikali in forum VBA
    Last Post: 12th March 2009, 08:56
  4. Drawn event
    By flajoso in forum VBA
    Last Post: 26th August 2008, 11:09
  5. The event OnElementCreated is not executed
    By markclemens in forum VBA
    Last Post: 21st February 2008, 14:31
