Showing results 1 to 7 of 7
Thread: M-bus trouble with variable set up
    22.04.2021
    11
    Lächeln M-bus trouble with variable set up
    I try to connect device with m-bus protocol. I have virtual com port on zenon server. Now, i dont know what i should put in offset in variable setup.
    I got the connection with device with some m-bus software. I got the frame from the device and it looks like that:
    I should count the place number from the first sign of all frames or starting from the first sign of data frame(begining from OC 78 signs)?
    I tried a lot of combination and i failed.
    Help!
    1,114
    Default Re: M-bus trouble with variable set up
    Have you configured the right baud rate (as well in software controlling the virtual COM-port as in MBUS driver)? Have you configured by variables the Net Address = 1 (compare "A=01" on the screenshot)?
    Do the variables have correct driver object type (PLC marker) and data type (INT2 -> INT, INT4 -> DINT).
    What are the symptoms in zenon? Are variables INVALID, or empty, or have strange values? Do you see in LOG (DiagViewer) errors or warnings?
    1,114
    and.. have you read in Help the topic till the end: Service Engine drivers\MBus32\Creating variables\Driver objects and datatypes\Driver objects
    22.04.2021
    11
    Yes,
    I did every thing you said. Com settings was good. The slave id was good. I read everything in documentation several times. In diagviewer there was nothing about the com i used.
    I don know where the problem was. I added virtual com port one more time with the same config and now it's working. I think the com port wasnt be opened correctly.
    Thank you very much for the reply!
    1,114
    I neither have experience with M-Bus, nor time to read the protocol papers, but from what i've read in zenon help for the driver and see on your picture i would propose you to create variables 8 (or 11) LREAL or DINT variables (up to you, i suppose the driver converts received content to the data type of variable) with offsets like numerated (in magenta) on the screenshot:
    1,114
    oh, nice, we synchronized the responses .
    Did i guess the addressing right?
    22.04.2021
    11
    Yes, that is the right addresing
    Thanks a lot one more time.
  1. Replies: 1
    Last Post: 3rd December 2020, 12:11
  2. Trouble on installing Zenon 7.60 Editor
    By haxziq in forum Engineering Studio & Service Engine
    Last Post: 29th June 2020, 07:44
  3. MATHDR32 variables trouble
    By woohyen2 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 27th May 2020, 13:51
