Thread: regarding zenon logic
    24.01.2022
    5
    Default regarding zenon logic
    I m trying to make a logic for getting output KWh of solar power station in every 5minit and also i need to get the difference of kwh (ie current kwh -(minus) previous kwh.
    how to make this logic in fbd. what is the function to move the integer value from one to another location.
    please help me to solve this problem.
  2. #
    1,117
    Default Re: regarding zenon logic
  3. #2
    1,117
    I'm not sure what is/are the missing point(s) for you:
    - the FBD in general? (then, why not in another language according IEC 61131, the zenon Logic supports few, I prefer to program in ST, is very similar typical programming languages)
    - that in a program/subprogram/UDFB you can create additional private variables to store previous value of an input variable.
    - how to use a timer function to evaluate the data at particular time/period?
    - that a zenon variable can be configured as 'externally visible' for zenon Logic and used as input for any calculations there. The result can be a additional stratonNG variable or INTERN.
    and I have no clue what you mean with "move integer value" or "another location".
    This Forum is not the right place to start a general programming course; from the scratch. And for use of Logic there is a training.
    If you need just a periodical calculation (made in zenon logic) of values of some zenon variable(s) to the results on another zenon variable(s), and those 4 hints above are not sufficient: contact the support officially and ask for some small example of periodical calculation of process data.
  4. #3
    1,117
  5. #4
    24.01.2022
    5
    Lächeln Re: regarding zenon logic
    thanks for your reply .
  1. Zenon Logic to check if a Zenon Variable is online
    By doublem in forum zenon Energy Edition
    Last Post: 28th March 2019, 13:06
  2. zenon logic doesn't communicate with external variables in zenon
    By mashjj in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
  3. Re: zenon logic doesn't communicate with external variables in zenon
    By anjali.gk.nair@gmail.com in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
  4. Zenon logic
    By sidramsatyal in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 1st July 2014, 09:45
