Showing results 1 to 1 of 1
Thread: Logix odva driver : Communication fault with some variables that belong to udt
    22.05.2015
    Default Logix odva driver : Communication fault with some variables that belong to udt
    Good evening,
                we are encountering a strange problem in a project where I am using LOGIX ODVA drivers.
    On an already perfectly working project, where the connection with PLC was working correctly for each single variable, we implemented a modification for which it was necessary to add some new variables.
    On the PLC side, a dedicated UDT was created (see pictures) called "MOT_DIV_CH_A" Within this structure, there is a sub structure called "HMI". Within "HMI" are the added INT or BOOL variables concerning the implemented change.
    During the first bench test session carried out by a colleague, he detected the absence of communication ONLY regarding the new HMI variables with the PLC.  At this point we wonder whether a syntax error has been made in the symbolic addressing field (the "IDENTIFICATION" field has been used) or there are some limitations in the driver, in terms of UDT knotting, of which we are not aware.
    I suggested to my colleague that he try :
    - import the variables from the driver (see page 35 of the LOGIX ODVA data sheet)
    - Try launching Diag Viewer tool to obtain more details on the communication fault of these variables.
    1) Have you already experienced this problem (I haven't found anything relevant on the forum)?
    2) Do you have any further suggestions for solving this problem?
    Please find attached 2 screenshots, respectively containing the structure of the PLC-side variable addressing and the HMI-side variable settings.
    Thank you
    MATTEO MAGNANI - SIDEL S.p.a.
    Attached Thumbnails Attached Thumbnails PLC DATA STRUCTURE.png   HMI SETTING.png
  1. Communication with same LN/Net address/Driver name
    By azami in forum zenon Energy Edition
    Last Post: 9th June 2022, 08:08
  2. Replies: 4
    Last Post: 8th March 2021, 14:27
  3. Communication problems with Logix ODVA Driver
    By ManuelaGomes in forum Drivers
    Last Post: 12th May 2017, 09:11
  4. Fault when installing a new driver
    By mjackson in forum Drivers
    Last Post: 30th October 2014, 20:38
  5. Communication Between Zenon to RS Logix-5000
    By navaneet in forum Drivers
    Last Post: 30th April 2014, 12:54
