Thread: How to use command processing for IEC 104 and IEC 101 process gateway?
    24.12.2021
    5
    Default How to use command processing for IEC 104 and IEC 101 process gateway?
       i want to check the command through process gateway using command processing with interlock check,
    i am using IEC tester for executing the command. command is also executing without command processing and interlock check.
    is there any setting need to enable in order to check the interlock?
    here shown below which i configured
    1,107
    Default Re: How to use command processing for IEC 104 and IEC 101 process gateway?
    Have you activated 'Select routing' checkbox in the Sector (COA) settings of zenon Process Gateway?
    1,107
    Hint: if the only interlocking to check is the 'local/remote', then you will not need to route the SBO via Command Processing. You can just link in zenPG the T00 IOA=2 variable and disable/enable remote command - pro Sector (COA) - by changing this variable value.
  1. Process Gateway Command functionality
    By rahulindore05 in forum zenon Energy Edition
    Last Post: 10th December 2021, 14:50
  2. Replies: 6
    Last Post: 31st August 2021, 15:25
  3. Replies: 6
    Last Post: 18th March 2019, 16:29
  4. Replies: 3
    Last Post: 14th February 2018, 09:48
  5. Aditional command butons in command processing screen
    Last Post: 6th February 2017, 09:52
