Thread: Command Processing with Interlocking
    24.12.2021
    5
    Default Command Processing with Interlocking
    we having 10 no's of outgoing feeder, For breaker command we are using (CSWI/Oper.ctlVal)
    eg,
    1.H01-OUTGOING FEEDER1 (H01_CSWI1/Oper.ctlVal)
    2.H02-OUTGOING FEEDER2 (H02_CSWI1/Oper.ctlVal)
    10.H10-OUTGOING FEEDER10 (H10_CSWI1/Oper.ctlVal)
    and interlocking variables will be Ind01/stVal
    eg,
    1.H01-OUTGOING FEEDER1 (H01_Ind01/stVal)
    2.H02-OUTGOING FEEDER2 (H02_Ind01/stVal)
    10.H10-OUTGOING FEEDER10 (H10_Ind01/stVal)
    So, we need to create command processing with interlock for each and every feeder, or single command processing for all the feeder with interlock check.
    Arun
  2. #
    1,117
    Default Re: Command Processing with Interlocking
    The wildcard works only if all variables of particular feeder have the exact same prefix (or suffix). It will not work if you have either "CSWI" or "GGIO" in wildcarded part of the variable names (typically prefix); neither if you will not have some text (typically suffix) clearly distinguishing and identifying action, response and interlocking variables.
    You can configure the driver to use 'Symbolic Addressing' and rename variables to assure that as well CO, RV and this interlockings have suitable names, e.g.: H01_FEEDER1_CO, H01_FEEDER1_RV and H01_FEEDER1_ILock. Then in Command Group: the 'response variable' = *_RV, the 'action variable' = *_CO; and in node 'Variables' you could define (typed manually) X01 = *_ILock. Then in the Service Engine (runtime) the wildcard will be replaced by "H01_FEEDER1", "H02_FEEDER2", etc.
    Thus, in case of your 10 feeders with same interlocking condition formula, you could create just a single Command Group; but only if you will use well designed name syntax.
    Otherwise you would have to create 10 Command Groups. You can use copy and paste to make 9 more from the single one, but if you later on would need to change something - more workload and higher risk of mistakes.
  3. #2
    18.12.2017
    55
    Hi Arun!
    Why would you need to do that?
    Wildcards work in Command processing.
    From the help file: Manual ->Energy Edition ->Command Processing
    Name replacement
    To simplify or to generalize the definition of the variables, the variable references (for command variables, response variables and condition variables) can
    be defined using a name replacement. In doing so, wildcards '*' can be used.
    Wildcards are only permitted as a prefix or suffix, i.e. *xxx or xxx*.
    As a result of this flexible definition, generally-valid procedures can be defined, which are then applicable for several data points. The number of command groups that must be defined is thus reduced considerably.
  4. #3
    24.12.2021
    5
    Hi FredrikV,
    we facing issue once we using wild card * in condition variable, getting errors in output window. without condition variable it is working fine.
    eg,
    Command variable (H01_CSWI1/Oper.ctlVal) used as */Oper.ctlVal
    Response variable
    (H01_CSWI1/Pos.stVal) used as */Pos.stVal
    we need to know how to define condition variable name (H01_GGIO/Ind01/stVal) using wild card *
    Regards
    Arun
  5. #4
    1,117
  6. #5
    24.12.2021
    5
    THANK YOU...
     AS PER YOUR GUIDANCE I CHECKED AND IT IS WORKING FINE
  1. IEC 870-103 driver & command processing
    By HMIdeveloper123 in forum Drivers
    Last Post: 10th February 2020, 13:34
  2. Replies: 3
    Last Post: 14th February 2018, 09:48
  3. Aditional command butons in command processing screen
    Last Post: 6th February 2017, 09:52
  4. Command Processing
  5. Action buttons at the command interlocking
