Thread: CE7 Runtime error when developed in zenon 10.
    25.05.2016
    7
    Default CE7 Runtime error when developed in zenon 10.
    Hi All,
    We often use Beckhoff IPC's running CE7 for simple projects, Because its CE7 (ARM) zenon 7.20 is latest CE runtime. this has worked fine for many projects developed in the engineering environments of7.20,7.50,8.00,8.10 and 8.20.
    Now when developed in zenon 10 the attached error occurswhen starting the runtime.
    I have never used 5.21 so clearly this error is also wrong, UK support have looked at this issue without success.
    Please help....  I dont want to have to remake the whole project in engineering 8.20.
    Thanks James.
    1,107
    Default Re: CE7 Runtime error when developed in zenon 10.
    it is a known issue in zenon 10, sorry. And the message is misleading, sorry*2. The compiled and transferred PROJECT.INI file ends with LF and not with CR LF chars like it should. You can try to fix it manually (open in some text editor and save and transfer manually) or look into Knowledge Database for zenon 10 build with fix.
    1,107
    The zenon 10 build with fix is not released yet - in quality assurance (testing) phase. When it will pass all tests successfully - expect build 92805.
  1. Zenon runtime 6.51 alarm filter error
    By dahmane in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 22nd February 2021, 17:57
  2. Error Zenon Runtime
    By nxb_200388 in forum Engineering Studio & Service Engine
    Last Post: 1st March 2018, 09:23
  3. Zenon Runtime error
    By azami in forum zenon Network
    Last Post: 23rd February 2018, 08:11
  4. Zenon Runtime error
    By azami in forum zenon Energy Edition
    Last Post: 19th February 2018, 10:35
  5. Zenon CE Runtime error
    By yzhyff in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 17th December 2014, 19:22
