I want to use from the file transfer function for transferring comtrade files from device to pc by IEC61850 driver but some error occurs during test. The zenon version is 6.50 SP0 and also my device is the F650 from GE Multilin. You can find its file transfer datasheet as attachment.
1. First of all I am sure that the F650 has comtrade files in its memory and communication with zenon established successfully.
2. I create two string variables with the name “Server1!Command” and “Server1!Directory” with object type File Transfer in 61850 driver. I define Net Address 1 , offset 0 and String length 100 for both variables.
3. Then I create two Dynamic Text in picture for above variables.
4. I send the set value “DIR FileSpec” to the “Server1!Command” variable in runtime but “DIR ERROR’ appear s in dynamic text. Also red squire appears. Please find its screen shot.
What do you think about my problem?
