Thread: GIS Control ActiveX Element Error in Service Engine
    23.08.2021
    Default GIS Control ActiveX Element Error in Service Engine
    Has anyone encountered the error message
    "Failed to load GIS configuration. Possible reason: the file is corrupt or invalid"
    during runtime?
    I followed the steps in the manual "GIS Integration" to create the GIS Display
    - Create and save the configuration file in GIS Editor
    - Create the ActiveX element in Engineering Studio and selecting the GISControl.GISControl Option
    - Create Screen switch function to navigate to the screen.
    During the first service engine boot up and navigation to the screen, the map data loads without issue.
    However, any subsequent navigation to the screen or utilization of the reload function results in the following error:
    The only way to load the GIS is to completely shut down the service engine and start it again.
    Any help to resolve this issue would be greatly appreciated.
    17.12.2020
    4
    Default Re: GIS Control ActiveX Element Error in Service Engine
    Hi ,
    I am having the exact same issue right now.Did you solve the problem?
    06.06.2022
    I am having the same issue. Help would be much appreciated
    22.01.2018
    Dear all,
    we made a ticket and the issue was that the .xml was not part of the project files it was stored in another location. Please make sure that it is stored in the editor files here:
    C:\ProgramData\COPA-DATA\<SQL Version>\<Project-GUID>\FILES\zenon\custom\additional
    If it still doesn't fix it for you please get in touch with your local support.
    BR,
    Wolfgang
  1. Web Engine Deployment Tool Error
    By rahulindore05 in forum HTML5 (Client & Configuration)
    Last Post: 18th February 2021, 14:04
  2. Replies: 0
    Last Post: 13th October 2017, 16:51
  3. Size dynamic for ActiveX and Control Elements
    Last Post: 12th December 2013, 11:34
  4. ActiveX Control in zenOn
    By sebastiank in forum VBA
    Last Post: 27th February 2009, 19:38
  5. Replies: 0
