Thread: Monitor Administration (2 monitors)
    20.09.2021
    7
    Default Monitor Administration (2 monitors)
    Greetings!
    I have a question.
    Does  "Monitor Administration (2 monitors)" can be connected with VGA? because i try to connect my computer to a monitor with VGA cable it did not show anything
    However when i connect with HDMI cable, both 2 screen able to perform.
    10.12.2007
    280
    Default AW: Monitor Administration (2 monitors)
    Are you sure that you have ONE graficcard with TWO VGA Outputs? Maybe your computer has an onboard graficcard plus one extra graficcard. You can't use 2 graficcards at the same time...
    1,107
    Default Re: Monitor Administration (2 monitors)
    first check if both monitors are available for Windows and standard programs like Windows Explorer or Notepad.
    zenon accesses monitors via Windows interface functions, thus if Windows has access then zenon will have too, if Windows does not have - no way.
    03.11.2021
    Hi, I am also facing the same issue.
    If anyone can help then please let me know!
  1. Monitor Administration (2 monitors)
    By andrea.ornago in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 28th September 2020, 13:15
  2. Zenon Monitor Administration Problem
    By konsistek in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 29th May 2020, 08:22
  3. Monitor Administration
    Last Post: 12th January 2015, 05:48
  4. Monitor administration and screen resolution
