Modems that are tested by COPA-DATA for message-control
We cannot give a 100% guarante that the modems which are used within our tests will work in every systemconfiguration. But with the following modems, our tests are working very successfully.
Analog for voice and Speech Messages.
Microlink 56k Fun USB – Devolo
56K USB MODEM – TYPHOON
GSM
WMOD2 / FASTTRACK M1206 - Wavecom - modem seriell
Multitech Multimodem MTCBA-G-U-F1 GPRS Cl 10 , 900/1800 Mhz - USB Modem
BEACHTE:
Für das Modem Multitech Multimodem MTCBA-G-U-F1 ist es wichtig dass die Übertragungsrate "115200" gewählt wird.
Re: Modems that are tested by COPA-DATA for message-control
Further Information about modems: :mad:
This modems aren’t operate on VISTA SP1.
Additional Modem which are tested and running under VISTA
Analog modem for voice and speech Messages.
Longshine LCS-8156A, 56k V.92, USB from Longshine.
The GSM Modems are tested and running under VISTA.
SIEMENS GSM Modem TC35i und MC35i modem serial
Note: If the used provider in Message Control requires a UMTS NET, the modem has to be UMTS enable.
In this case we tested successfuly the USB-modem Huawei E1550
Current information about the Modems which we have tested! :)
Analog Modems for Voice Messages – wav files and text to speech
- Longshine LCS-8156A, 56k V.92, USB from Longshine - XP und VISTA und Windows 7
- Microlink 56k Fun USB – Devolo mit InstallationsCD - XP
- 56K USB MODEM – TYPHOON mit InstallationsCD - XP
- 56K USB MODEM – Modem Blaster Kreativ - XP
GSM – Modem for SMS Messages:
- SIEMENS GSM Modem TC35i und MC35i modem serial - GSM-Modem - XP und VISTA
- WMOD2/FASTTRACK M1206 - Wavecom - modem seriell - GSM-Modem - XP und VISTA
- Wavecom Fastrack model M1306B – GSM-USB – XP und VISTA und Windows 7 - 32Bits und 64 Bits
- Multitech Multimodem MTCBA-G-U-F1 GSM-USB – XP und VISTA und Windows 7
- Huawei E122 – UMTS-Modem. XP und VISTA und Windows 7 – 32 und 64 Bits
- Huawei E1550 – UMTS-Modem. XP und VISTA und Windows 7 – 32Bits und 64 Bits
Attention 1: Please check if your Provider supports GMS- or UMTS Net. A few of Modems don’t run in UMTS-Net. We tested the in UMTS-Net the modems Huawei E122 and E1550.
Attention 2: If SMS text contains non ASCII characters the SMS is sent in UCS2 encoding and you need to get the Version 6.51 SP0 Build 5
AW: Modems that are tested by COPA-DATA for message-control
Hallo zusammen,
viellecht kann mir einer von Copadata oder sonst ein MessageControl-Anwender weiterhelfen.
Dieser Beitrag hier ist doch schon einige Jahre alt und diese aufgeführten Modem's nicht mehr erhältlich. zumindest hier in der Schweiz.:(
Welche Modems werden heute von euch eingesetzt und empfohlen. Meine Anforderungen sind wie folgt:
Anschluss extern per USB
Lauffähig unter Windows2008Server R2 64bit
Text-to-Speech
Kann mir irgend jemand helfen?
Vielen Dank
Re: AW: Modems that are tested by COPA-DATA for message-control
Quote:
Originally Posted by
sva
Hallo zusammen,
Text-to-Speech
Vielen Dank
das Modem Longshine LCS-8156A ist bei z.B. bei Amazon erhätlich.
Achtung: Nicht verwechseln mit dem Modem Longshine LCS-8156C1, dieses Modem funktioniert nicht richtig mit zenon.
Mit freundlichen Grüßen,
ich habe mir Aufgrund dieses Threads das Huawei E1550 besorgt. Leider bekomme ich es nicht dazu eine SMS zu versenden.
Ist jemandem bekannt ob eine spezielle Initialisierung erforderlich ist?
Thank you joao for your information.
However, it is interesting that you did the tests just for the operation systems on Personal Computers, such as XP, Vista and Windows 7.. Why not do some test at the same time for Windows Server systems, such as Windows Server 2008?
joao
The following modem is succefully tested by one of our customers with Message Control SMS messages:
- ConiuGo GPRS GSM Quadband Modem
