Can someone help,<br>Due to the large number of variable in a project circa 500,000 I receive "out of memory errors" using 7.60 webclient.<br>I start the runtime in 64bit mode but all the webclients try and connect in 32bit mode.<br>
Printable View
As far as i know, the webclient is only as 32bit available.
Thanks but there is definitely a 64bit option if you look in the setup files web client(x86) and web client 64
Hi!<br><br>Have you checked that you start a 64-bit version of the browser?<br><br>/Fredrik
<br>
<br>I am running windows 10 64bit. I have tried launching iexplorer found in the "program files" folder but it seems that it is intent on running 32bit.<br>I have tried launching the zenwebclient.exe form command line "zenwebclientstarter.exe -Project TGW_MAIN_151085 -Server uktcmms-01 -Webserver uktcmms-01 but nothing happens<br>
Hi again!<br><br>Internet Explorer should start as 64 bit in a 64 bit Windows but as always there are some settings required.<br><a data-cke-saved-href="https://answers.microsoft.com/en-us/ie/forum/ie11-iewindows_10/internet-explorer-11-64-bit-for-windows-10/92f38749-f370-4795-93d5-5d5a46e742cd" href="https://answers.microsoft.com/en-us/ie/forum/ie11-iewindows_10/internet-explorer-11-64-bit-for-windows-10/92f38749-f370-4795-93d5-5d5a46e742cd">https://answers.microsoft.com/en-us/ie/forum/ie11-iewindows_10/internet-explorer-11-64-bit-for-windows-10/92f38749-f370-4795-93d5-5d5a46e742cd</a><br><br>For the webclientstarter the following command always work for me:<br>"C:\Program Files\COPA-DATA\zenon Web Client 7.60 SP0\zenWebClientStarter.exe" -project Exampleproject -Server aNiceServername -WebServer aNiceServername -Zoom 1"<br><br>You may need to register it first! Check the following info in the help file:<br><br><a class="breadcrumblink" href="mk:@MSITStore:C:\Program%20Files%20(x86)\COP A-DATA\zenon%208.00%20SP0\Help\english\main.chm::/98424.htm"></a><em><span class="breadcrumblink">Manual</span><span class="breadcrumbdelimiter"> > </span><span class="breadcrumblink">zenon Web Server</span><span class="breadcrumbdelimiter"> > </span><span class="breadcrumblink">zenon Web Server, Web Server Pro and Web Server Pro Light</span><span class="breadcrumbdelimiter"> > </span><span class="breadcrumblink">Required components and their definitions</span><span class="breadcrumbdelimiter"> > </span><span class="breadcrumblink">zenon Web Client Installation</span><span class="breadcrumbactive"><span class="breadcrumbdelimiter"> > </span>COPA-DATA Web Client Starter</span></em>
it is not possible to run the webclient control in a 64-Bit instance of the Internet Explorer. This is due to the fact that Plugins (activeX) can't run in IE as 64-Bit controls, only 32 is possible.
You'll need to create your own OCX container to be able to load the control in 64-Bits or you use our new WebClientStarter.exe which is officially released with 8.0. Nevertheless with the language build of 7.60 the webclientstarter is also present in older versions and the command FredrikV posted works.
Hi again!<br><br>You might need to run the cmd as an administrator.<br>After that it's pretty straight forward:<br><br><img src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAsoAAAFWCAIAAAD/uCyyAAAgAElEQVR4nO3dv4vkRv7/cSVfPt9wnd3/oOTA2UT+A8QlhoV1YBYMEwlfcBgOJxdcJDC4YXGyiX2BYOnMDm YTB33gcLnADhxsdH+BP+DA4XwCtaT68X5Xlbqra3pqng+WO0+3 VCqVSqqXSj09zX6/bwAAADIiXgAAgMyIFwAAILOEeNH24+Ew9m2J6qRp+/FwdIF6nbq/3VCyldY2KH1orq8/QPVw3QTAE7ff75umG4yrjzd6XNtw0g2Hw9AJrybW0V+y7UejxM cTL+xW8NtFbqkcW77knk4jolvvbtiWKLcur21XGaG14o3ka5Wk vR6rvFm+UYa0ba3+xwKv6AwG8BTs9/um7cdxHI+XH+uHa+SPq03TbLmA+gUoRW700PHCSxOXSRcXNQXd 3q24kX/bfozv1dblte1qa3fD/GLbj3Yyn39I+e8U6kG03tDqbyx8xac0gBrN8aLvh7Fvm6bth77 rR/ParNxyGXdY5vV17NtlLeOKZt55mWVZd2TGG9rywrjq39SFhxMx XkxVVfZ3WmPZYetCbd5oKneaxkjkzS6Yo05a9dW9cIciewnxdj vteK2l6P1BPF6hdlP2aei8/XAHx/gAvXV5bbspo7JRunNIlpW119Moi5svq/U/dZsAcLYlXrTdMPZt2w/TcONGAOFGWbheHQeZ9arq/pfzgzJtIC8vxAh7+Ey9gM73nkuqcNZVAowwiLh3kMYiwv56VVx ugk+YPhFXMeuj1dNdRjhekfqI7SMdX7XdIpxhUqhxsKSty2vbn Q5YH37KYqzjrL7ssPZ6isAZIid+4gWA67Df7+drTzeMwzD0rXf tCt52W+wbxXkpd317HPYviPrycm2CVRIcF2374fgUaJ3rlrfgz QMct2RvU7tbNdvB/X8jXmzMF7EBxkkXcgPKxytWn1j/UBpi06dj/Nv9NQrFxuety2vbnWZ8rAcQ0nyR1YBOrpl+0l6P1UUNNfqMBvE CwJU4xov5LkuMA5HhNvqGe22zlhLm24PLZ4sXbT8OXTdMweqke KFNeqv1n7bT9sMS46SnKWkxQ2+Gw9DZbwvTPvEZhUB9wvHPeD9 fvLDG2YR4sWl5bbtujaX9VD/ZOfadeAjs10+oVOBpD/ECwPUw48UiZbhVZy/861tsOFoWUh4V5J69mD8SMHRN0w2j8VkTZQtJ8cJ+FiTWvxsOQ 9f2w/FJlNfuTjsk7IT/+jTEJA7sCQOvUJ/SsxdOFaKfpdi6vLZdeRbF3EiwWPHwBl4PlON92kcNEcQLAFdiv 99Hn334C2hjYMpnKZSPbahz9u7yKdsIa/vxMI7jMnHt/qZM8sMRY5vTHbP02Quj/m0/jsMwHmPNMIi/oJN4r60u1g2Hwzh6A764cMq25KOvx017f3PEC7sPiG+euXzKdp M6sV6U/rpen3mzbtbStky8AHA9gvHCm1V3byndx8P6cLU8StZ/kd+7RZMfPgefzKQ9X+gGOwqYH26U9lcfJpc1pskI+zG8X3/jYb75XD/QDqpYUzvv2Zsw5+yVqCbVJ9Af1OO7KV4YpTgbCBzc2P4mLJ+0X fHg2suvb3if4dUPrl8fq5395zHi40ftwCwLEC8AFMWXgj9SyR8 oAIgXAIojXjxSxAukI14AKI148UiZv4vAuAEF3QTAAyFeAACAz IgXAAAgM+IFAADIzI0XbZ/211JTl7ti8S9GKk38Lcgn5/qOSxgfmwQAnx0v9O/l8W1ZNvCb//pXAnh/ncH/cuvIZd368iNv1Lq2YUxu0M2Dl/6NIVdF36/yxyXcTxLWvuaGFi3fuuJ9kYa2N49xLwE8JDNebL2CpP9u5Po9y PaXDjrf8Gj92ZHD9Mcq1Q3E403bj+sXclo/XKPzv+zcGxrbfrja/b2i4erMfnJFe5IB8QJAHmu8CP0RC+1u+IRrjpkv/D8msnx75vwnwNQEkbDpth/Hvh+OX0A6GH9bJPT3w6T9nR4FmV/RaVZa+qpEa6ZFmYFJ+KrtyJcxClWP/oUy589xSPs1/1EW4bBvKsdpTvE7Sq2S9OMibjdQzy30ftLos2vWF2UmbFkqJ7G dve93d17uhsPQT8vPpRlZ6ezjsr0fAoARL+R0EfvbCtvzhTEEm qPhfA3zvqtZvpIlTZxMF9duGPu27Qf/D3MLhSj7e6zd+tXh7n85P6T8XZTlB+HyfdJf6gh/XbpaT2W/lkoYy28tZ8mJQtMG9iv8N02c+qT89dcIvZ+YHVD779QvOxfWVe uv7YvcnvOTjvm77te1Mx4XZi8AbDPHC/kvJUWvKaE/sCSxrmXd/IfRD+5l0Vha+7NdaTeMY99Ofz3s+AfQI/FCK9d7pLPkAvmxtfynIfTl5dps2NV50aQ/XCb+TTbzdWeFtP0VygntyYZ4oW538980kan9RDtAyXsiLmGP/mL9lT8topTqHh8l/553XIgXALYx40V0PBRsueq4H5o7zs9a96Up8SI108yf+NCGR/EuWb39j3/q0lpKmOcPLn/BeKFvNzDLIsSLzeV4MzOnxQt1u/nihdhPhGklqR8lZXCpnGD95edEYnuG40Wm40K8ALBNcPYiPo6n z0i72WJ+yR5f/efb8gObpG2uHyiVXwhPwruV9zcZGwaXhZRBOPfsRSiO6bMO0RW U0TyxHO3m+bpmL+R+opToN8+m2QutIHkp8yRR2nNzvDjluBAvA GwT/uxFdJI29aKjfKbBfFkYG6XhMv1xTPTZh7+Atr8pl2ntYyrGusH lk4aCiPnp+7Lu4M+Rm9tNiRfOZwW2lON+5MBNU8p+hWOfsd3w8 NxJf6g9ZXPWwB05JtYnKVVJuS8eZpT23BwvTjku+vFKbWcAT0v 0N0fMaVTv8pKYLjrzU/b2hK9RvD3fLC+f9FBa3SHzOixXR9lffZLGqKk5rJvlC2Oe1Jop E9kJe64cL3m7Ccdc+LRtcjnm4qP9CxnifgWOi9rOF40XalMsL4 99m3QSiOVo9df7j9ieJzwc2XZcwq8TLwBIynzvBR4VDiwA4Dyl vrUTjwjxAgBwnif8N0egIV4AAM7DX0wFAACZES8AAEBmxAsAAJ AZ8QIAAGRGvAAAAJkRLwAAQGbECwAAkBnxAgAAZEa8AAAAmREv AABAZsQLAACQGfECAABkRrwAAACZES8AAEBmxAsAAJAZ8QIAAG RGvAAAAJkRLwAAQGbECwAAkNlp8aIbDmPfZq9MMY+9/hdxgUZ5ku3c9uPB2e22Hw+ToTun6KfWnpXub9uPZ3YEoyC1Xwn 9EChqjRfdcJjF+2Tbj95C/rVgOY2Mso2TYTo51hNjLmA9afwzx3zv+EZgu05Z62JS/fPKcmU0280ubX0n234k1vjsfhI+wI+CswNClpCaJsOoEui38nE RzpdI+09vpvSE8GH0y3GWF2vqn8lXP0AGrz+ikzqCft4pxeWJF xuuY/7xTVpzXc1cfOMFTrzOhzroBS6g8EzxwumJbT/Emlzo0v5LzituT2378TCO6/XDjBf2pfC4SNuPaydp+1FY3NruskhS/fPKfePVDcb50Q1mfDK2c85WE9bN0k+cF7vh8SWM03pPjj4nl6E cF/l8Cbd/249j3yWN6up5GilH7GjK8hc/T88Xve4lrJGwCf28u2gbnXxFsS5YGquH2utK1/xAKdE8b/bzjeXjVPv9PtYTlBTs9TvxNHMCqRcvhq4b5hfFeGF0Hreax+X0 7Qb3Sz5vrMArD+HWj8Lywk2anbHc1NwNh6GfVhq66f3Ui7J/aqmjtXL3Y00sRS4kefqJe4DtcW/s26UBY3fhjd/YyyFQyjH3dy4nrf31HZBqo73rva7cRUn9cFnBrZ1yXJTzJdD+5 jmVNDUlnqexcqSerC+v9B/l9BLbc77QCA2tzu4oy8ebobGve3p9xO4piozUcr5R+mF6+4SvY zFJsURZyH45cJNo7FP8hFvL2Vo+TrXf72PpV5tk8/rGfE+9nF3OEnK8WG/FlXgxH3+/mscV9O1OZ4yyb9Fxz62Av0yg5cQzxzwP1v+eE0E3TOe2VKq6Je HUEg6YEdfVlaMXhFz9JBgv1uvb+rrX/kYgFTOgUk7T9qN1N2P0kkj7b2mJUPjwOrDQHyLlJ+R6fXPCCWa 23PJOyuignKfRckInnhye9Kqs83jHn6T2nLqDP3Wj9Stt+Ugd5 OuPWh/zVjq4gVMnQ5L7W2h/T5u9SJtQ6YbD2Pde3nHPhHiwUa7zSj/fXj5OtN/v06axBG4fOvbEth/GZfZAeN9b35hsCMULv5prvAhsdwnlkd43v6Ld+ktnX2BmLX5d9 S6pRntYUxuBexwlNriTGEl3CdELSa5+4k9amqPbWgetPywV9Y6 FedHwy/F3xx4NxPZX90i/qUu+3Cv9IdivhHISJy+UBnXbfx30YsOKHi/C5QTzZnrobyIXmHU1uwC5++hvpJwX8vUnrT7RDcTOu7P7W2h/T4oXiSt5Fymz2dZbhOSs4p6NSj8/rXyc4Jx4IZ8mbT/OTzwS40XTLIufOnsR3O68bNJnopR5RaNu/q2jNMgol0mHGKvk4c0/Stp0wbqt8A3Y1vuUXP3EaQjjHbmioX6jz16INXUOwTnx4vzZC6 0/OG/6RfkHbvvshdT+7uVYqs3BvvMT44VejvxKZHmtQd3TXG1PZfhU+ 9VJ8cK//iTWp1i82No+aXsvbzdpHafs+cdjUIifzUqZyuMdK2icXD62SPj sRYh3DRq6bhi6KTC4H9TSh4nphFTihTmp5Za3nMah7brlaPX3l haz06blA63lvxwZ3vx7D6Xu3ltKgcrcoS5TPwmP/tHR1ChsuWNJiinapMZDxYukS7c8keENAcrwK54voebR0o5WNek 8jZUjXQci25XnQNx90NrzwrMX6vUnrT5n5/qz+1veeJF+lXCWtNLvpguTRZxEcxc4o3ykm35zxLm1tz+ZHLpJ tnpf24+HcRyXG0vzt0LcZefljTuhYdDmbo0Qspaw/hDbrlE7aU4gkBe8e7NxVE8c7WLrbC1wdx4c3uxzwmoJbxPylIw 8blsDdewsy9NPtsYLu0GMXZdmqULlmM1v7MqDxYukK3HKjI5yX JTzJdA8CaFUqZnR72LlCLEnul1hmcgB1ipqFKX1qxPihXz9Sal PSh8Innfn97fQ/p4+uIs74eWdZWFzRfP1rfc0RjnqaXpO+dhg+d4L8xbCn7rUe5h 5CP2JKekuc+lj1tE3ltfmbp2SrPtQabvOXZF+q2/O9urL+2N0wvLuPkj7pg5v1sLuaCI0aHQ2xitqeXXs27T7lBz9Z Gu8aJTj7t33RjewFiPcZJ4dL7zb8OMy2uveW+Ly8X7rriN3lVi 8E59ZhNpBOU+j5Shz4uHt6udpWnsqw2dC+8TPC/W6l3R808Y26fjm7G/6/orXsVAtlaWEeGEVft5GVwm3MdvKx8kyfCn4CU/nrkpq/cO3rIjJ3k+EYespHaDHft5t9dT2F3js+JsjiXhCd3WcJ0QcIQC 4HsSLqHke7QndGD8WKU8RAAAPgHgBAAAyI14AAIDMiBcAACAz4 gUAAMiMeAEAADIjXgAAgMyIFwAAIDPiBQAAyIx4AQAAMiNeAAC AzIgXAAAgM+IFAADIjHgBAAAyI14AAIDMiBcAACAz4gUAAMiMe AEAADIjXgAAgMyIFwAAILPT4kU3HMa+zV6Z69b248HZ7bYfD5O hO6fop9aele5v249ndgSjILVfCf0Qj8rmfkJ/wKO0xotuOMzifbXtR2Gh9SzIMOQ+BGcHhCwhNU2GUUVuz6ZptO Ni1nTZdrD9pzdTLkPhw+iX4ywv1tTZbmB/r4afgWIH+qSOoJ93SnF5hpMNCc8/vklrrquZi6+7u7EQY41QB91YfgaZ+8l19Qex/QPL59ouqjDFC6eHtv0QO+JiV7de7AZ/aLp2pwWFHDetchnKcWn7cW3ath/nRULt3/bj2HdJo7pVjHvxCpQjXimU5bPd6F+OX8Xs8SJ83l20jU6+rHdD wmlt9VB7XaOvxsoxurb3utjP1fIvOYhl7CdX1h+09teWz7Vd1G K/38euGEo6FvqF3f/tcW/s2yUJx+7CndfX9/RyzNA/l9MNh6Gflh266f1IT9ZO4PBDEHEt5S7K2i/3tsutnXJc3JeX7avtv7yVNGvg7E9yOdoVSl5e6T/abanUnlPhyzvajIoVlZTl483Q2HMuen3E7imKjNTyuKX0w/T2ESabNgxaScOBspD9cmjwWvcpfsKt5YTKl+528vS3fP3k2vqD XJ9w/xGuw8p1O7Uc995Gvv5rhHLsAc3pGFlmv5LGKX1cONg3j37zyOU 7J1T8/Lq8/X4fS8Xa5FtsUtC5rba6lftfzg9Gv/aWEcpp2n607maWq83hMHTT/x8PR/hCGl4iFD7s183z0vzv2Kyo/zRGmQz1Njf2bSheLO+kjA7uBqT5EamcUOCUw5NelW5wrzVCe7b mcxej1lq/0paP1GEZLZYaB+sTvjhLjbPx/eT+Ftrf0+4a026gu+Ew9r13HXXPBGdAkQuSllH6eax87UJ23NL J/S1XP7m+/qC0v7q8fB3Wr9uh7WrXT6UckVbOuq6fQcXlN9LqqZUfGu8Ct7v J4+mD2e/3Jzekt/PWC2738nuUu/7S06w3zB8SeqZ9clvbiTe4kyGFm52k09u/izLPb7WphfZImbxQGtRt//ViFut0erwIlxPMm9HJLqcksWM4q9kFyN1HfyPaEscF2n4Yx3n8 ErKSVp/oBmLn3dn9LbS/J8WLxJXsG8JlN6e110tjclZxz0aln6eUL01inNvfcvWT6+wPQv sHl5eWCFy34/cp2n1D8gnslzMXNQyj3gZp3VOk1DPpuLjjnXaHKbWDdCP4oM6J F+I4JA7O8r663cO6H9iU5txccE680Fsi9fR2KmNPhK1v+kX5lx 2tb+nxQmp/93Is1eZg3yOI8UIvR34lsrzWoM7FXm/P8OXe38xJ8aLtx6HrhrFv54ol1qdYvNjaPml7L283aR2nbHP4N M+FTVfAbjhYN95CP08p37qBX9fL0N/O7ydX3R/M9teXF6/DwSOtXBbE+m8cM4PX4ePb3gv68tFNKBfchPK18c5aKTqeHksSL nUPJuGzFyGJeU9vbvmmYUnMac0aCYul40XSpVsOpt4prwy/VvGx2VW/W29qBStdhMqRhvXIduU5EOGWU6zxhWcvpsW7YeiaphuMD6im1S cpv4TOu7P7W954kX6VcJa00q9z/7ihCuvyoX4eKN8bT+baZelvGfrJdfeH+NSBusS2eKHXZeOgGdq n+aAdtlwRUun3TZEZIme8c4pUbwDtoqZ+eA3p4vibI040tT+xL J+VR9698IZ4YXfHdZJTbxv9sC0vG7vyYPEi6UqcMqOjHBejqaw f0np1tBncSYd5X2LlCLEnul1hmcgB1ioqzxEG2icpXozjuO78O K4dNFqflD4QPO/O72+h/T19cBd3whvfrKFl/m/z9a33NEY56mkaKN/ox06hZ/e3fP3kmvuDs4C0vLorgeuqdlVI3FNnJaEfqh1lOV7bztkUWj31 +8X4Vs0yQ+3QDYd5Fu3hLd97Yd5q2lULxou0vQ5O5ghbde97ox tYixFuHs6OF95tuDGRJdbTfUtcPi2gK8dFbLeUxNLE20Gse0I5 ypx4eLtu/9nansrlMqF94vcq/oT8skLC8U27TknHN2d/0/fXWCVaVXmuzWgl902j8PM2ukq4jVHLT5rKP7k9c/aTK+oPavvrTS1ehyOxQDxkchNtjRdyOU7StH485RSWdykwCSHu V/T4pjwmWNa6jnSR40vBs00pzYRh6ypmegrJ3p5X7qntLwAsKh7v rvFvjlhz/9uncQEAeBQqHu+uMV6kPUUAAOCxq3a8u854AQAAHjHiBQAAyIx 4AQAAMiNeAACAzIgXAAAgM+IFAADIjHgBAAAyI14AAIDMiBcAA CAz4gUAAMiMeAEAADIjXgAAgMyIFwAAIDPiBQAAyIx4AQAAMiN eAACAzIgXAAAgM+IFAADIjHgBAAAyOy1edMNh7NvslblubT8en N1u+/EwGbpzin5q7Vnp/rb9eGZHMApS+5XQDwHg6qzxohsOs/i1q+1HYaH1qphhyH0Izg4IWUJqmgyjityeTdNox8Ws6bLtYPtP b6YMS+HD6JfjLC/W1NluYH+vhp+BYgf6pI6gn3dKcXnixYaE5x/fpDXX1czF193dWIixRqiDbiwfwMVM8cK5YrX9EDs1xUuf9WI3P L6EcVpQyHHTKpehHJe2H9embftxXiTU/m0/jn2XNKpbxbiDWaAcccRSls92o385fhWzx4vweXfRNjp5AqkbEk 5rq4fa6xp9NVaO0bW918V+rpZf6XQZcNX2+33siqHcLQlnrH09 tMe9sW+Xm47YXbjz+vqeXo55EziX0w2HoZ+WHbrp/cg1Rrughx+CiGspd1HWfrm3XW7tlOPivrxsX23/5a2kWQNnf5LLka7h+vJK/9FuS6X2nApf3tFmVKyopCwfb4bGnnPR6yN2T1FkpJbzjdIP09t HmGzaEGKSBmplIftlLTzY+xQ/4dZyQuU/xrsd4HHb7/exuyRtMjY2eezcVi/Xt/V1b+CafzCuK94yQjlN24/W3cxytTkchm76/2MsCV9gwkuEwof9unldNP87WL7XnoHJcW9zY9+G4sXyTsro4G5 Amh+RygkFTjk86VXpBrMKSntaz12MWmv9Sls+UoclVSw1DtbHv JUObuDUyZDk/hba39Pu59MmVLrhMPa9l3fcMyEebKZkFJ4lXQ9wrPw8T5UAJNr v92nTnQLvWuNNWpqjm3UjIYyGxhXPm50XHgQ06hXSHASs7cRvl 0IPdTdc7v27KPN6rza10B4pkxdKg7rtvw56sSusHi/C5QTzZnSyyylJ7BjOanYBcvfR34i2xHGBth/GcR6/hKyk1Se6gdh5d3Z/C+3vSfEicSV7pmDZzWnt9RYhOau4Z6PSz1PKZxIDKOaceCGOQ+ LgLF9I3IvVulRo9kKsqZMLzokX589eCLPP9oS1NiPtD0/bZy+k9ncvx1JtDvocy9JuejnyK5HltQZ1woXensrwqfark+JF2 49D1w1j384VS6xPsXixtX3S9l7ebtI6Ttnzj8egED+blTKVxzt W0IiVb03oALikhM9ehKj36Tb5DfUu0/wgRUJM0SY1HipeJD+B8EvzhgBl+LWKXxYLNI+WdrSqOY0upBe/HGlYj2xXngMRbjnFGl949mJavBuGrmm6wfiAalp9kvJL6Lw7u7/ljRfpVwlnSSv9Cg81EomTaO4CofJ5OAIUNf3miHlr0DSN/Qn24Fnp3QtviBf2BcCYzBdGmGA57qPnh44XSVfilBkd5biYzz3 MH/TmGZ3jGWwGb+55nVMKliPEnuh2hWWSngcJS69Faf3qhHgxjuO6 8+O4dtBofVL6QPC8O7+/hfb39MFd3Akv74gPRs3Xt97TGOWop2mgfJ6KAKUt33th3mr6U9 z6lcg81bfGi8aap3CufaboBtZihJvMs+OFdxtuPLgR66nM39ov ylUJzXy7wcN9Ne0ZVLQd9LnncDnKnHh4u27/2dqeyvCZ0D7x+3d/Qt6aeI8c37SxTDq+Ofubvr/GKtGqynNtRiu5bxqFn7fRVcJtjFr+SZ80AXCWDF8Knv3UFYatp 3Tf8dQuhU9tfwHgKbjGvzlizf1vn8YFAAAP6xrjRdpTBAAAcKW uM14AAIBHjHgBAAAyI14AAIDMiBcAACAz4gUAAMiMeAEAADIjX gAAgMyIFwAAIDPiBQAAyIx4AQAAMiNeAACAzIgXAAAgM+IFAAD IjHgBAAAyI14AAIDMiBcAACAz4gUAAMiMeAEAADIjXgAAgMyIF wAAIDPiBQAAyIx4AQAAMiNeAACAzIgXAAAgM+IFAADIjHgBAAA yI14AAIDMiBcAACAz4gUAAMiMeAEAADIjXgAAgMyIFwAAIDPiB QAAyIx4AQAAMiNeAACAzIgXAAAgM+IFAADIjHgBAAAyI14AAID MiBcAACAz4gUAAMiMeAEAADIjXgAAgMyIFwAAIDPiBQAAyIx4A QAAMiNeAACAzIgXAAAgM+IFAADIjHgBAAAyI14AAIDMiBcAACA z4gUAAMiMeAEAADIjXgAAgMyIF0Bl/vTPX/nHP/7xr/A/90pEvAAq86d//noPAAURL4D6ES8AFEa8AOpHvABQGPECqB/xAkBhxAugfsQLAIURL4D6ES8AFEa8AOpHvABQGPECqB/xAkBhxAugfsQLAIURL4D6ES8AnKBpmnfv3vmvv3v3rmma8LrEC 6B+kXhxdzsveHu3vvp+dzO/fLN77yxuLmis7y0rLr++brx8d2uuar9nr+RvweHXfF7r/e4mvnoCucWA2rx79+7//c//dxKG+KKPeAHULxQv3u9uljHy/W53t7xojJzL69NbN7e3N+YgbQ75d7eNl1Lc5Y31liXf726MaPJ +J65wH48Xcs1TQolIWlFosfTyT64J8DCcMJGYLe6JF8BTEIoXw nhnjp+uaeC3h3+7CHttaXn7vfk/b3e7m9s7942E6ibUPGu8EF4jXqBmS6RIzxb3xAvgKQg+HLm7dZ 5oxNOFEwCcIdO+uxeW90o7/scym2FMa6wPOpa3bnZ3xxeTc9FSQ6OqYsm741OPm91766GP9zD ITlfWYt6Tk7vb5ub2dnlgY7wl1eH29qZpbuXmBx7IFCzSs8U98 QJ4CmIf7TyOcvG5g/UtcyE9XsjLr+YccXd7HM/nYd0YmI9rre/NY7v/QQq15n68UEpeRnkzcwgl2i0mL2Zuy9hYI7WbUQcmN3CFiBcABE m/ObJ8akGfvTCHb2MpP14ImUIudUoSc55wn6QYn9Fsmqly1rbcD4 Cmz15ESpZSSKDF/M+lHvmFiNMn8t4BV4KHIwBkib+YOo/OgU8wOKRb/HVtbXl7kze7O/NDF7c76xMZ7irmtvy3o5+9MONFoOS0eDDQYbcAAArySURBVLEW 44SG5clHNF4E6gBcBT7aCUAV/Gjnzhyt11/k9H//wh37luHR/c0ReVJDHvunW3j7F0/WpfyHBcYrYnlizeWHI37JafFCaDHrMYf37EaJF5E6AA+PX0wFE BL9aOeR8rUX3hBqLHK8d7cXnctVlr93X3QeLGjVmOcJlo9Jqo9 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 9ffvmo+/CWeLaclIwvj4Gz6HAVSMeAHUL1e8+O33P569eBX9vMW0cPRzGM 9evOIRCVAr4gVQv1zx4uXubfPpmxOfifj/Pn3DIxKgVsQLoH5Z4sVx6iL6O6jp//72HyYwgFoRL4D6ZYkX3/74S/P8dUpumJZPShjPX3/74y/n1w3AtSFeAPXLEi9e7t42n/2QOV589gPPR4AqES+A+mWJFx99+SbxS7Sm5ZPixec/ffTlm9iW726Nfbm921Tru1t5jbvb5mb3/pwSEtddtpK+xfMt20qvvFPVk3f5eLQ27qrTOGb9/UOftyWzlFby4J5Zh3JVJV4A9csSL5q/fJX4XRfH5VPixRc/N3/5KrZl44J4d7s5YETLvKAHjxcXXSVjOYF44R964sU5dSBeAMgnW 7xI+8zmcfnED3huihfWjfV8a7vmjeMrN7udPz69393MS6/3xObYZRR1d9vc3N7eNDe7985Qt7u1VxQ3alfvuHBkdS81zfW1K rmWYN3Kiy86w7O1IadwqarOWk5OEnbE2mWjJsLqc9uKhzhQ/3C8UJvC2JxTH70niIdy7R5Sm9hVMvqbvyPiQYn+GH7lVi9WW+y yiBdA/aqJF+93N+Y4cHs3vbYOHdN/vd/dNO745Ez4W+OBV9TdrTOoL0PRMliYScTdqLgVdXVnL6TdX1fzS tBedIdnZd5HHLOttaT/EnZEa1hxdW9X4/HCOPSBeCG3T+KOaS87exktxG5YfwfVg+L/6Pdwrc+bO5q42KURL4D6Pf6HIzP/bmx9WbyC26O/tbp/g55YVPTFe2Ur4uqNsHNuvbZWIPAfGQs/eZf94S0QL8RDr89epNb2tAXSdyrc36Il2/u+dsvEjpqy2MURL4D6Pf6Pdq4RQf98X/wKblzyTxgji421zuInVCAWL/IUnnGXA/Ei5dAnbq5kvLi/j/e3aLwItO2myhAvAFzGI//FVOOCuI4y5nOS+3vnlbtb6ab83n78sbzuF5U+DokbDZejrO7vt Du7v/6XuFXp8YGyIblwoarh/4oOgbHVrdWW+CA/B1kPfSBeBJoiqT7Sy+4xSt8po78Z8UisprChYA/3X1GL1Ra7O+f3g1IQL4D6PfKv1fJmINar6MQcl6YXbr3xdZ4xt j9zaIwg5ttbbnOFjVpVb+TPS3qrCx9iEPbl9nZa3CpKfFGq87I dv/BAVRulcPfQSK+EVzetDWE0hXjo76QnJtGm0Opj9wRpAa/zpOyU29/WlUKfwbR/DPTwUJ9PPzWIFwDOU/hLwafl49niYl8Krs8JXNDlN5ryWOEpoymuC/ECqF/hP2k2LRyPF7n/pJlx/1tumCm4UeJFGE1xXYgXQP34g+wACiNeAPXLFS/u7++//v5d8/E34d9QnZYMZYsvfm4+/ubr79/lqhWAa0O8AOqXMV7cT49Inr9O/A4MOVs8f81fMgPqRrwA6pc3Xvz2+x9//uu/TkwYX/zcPH/957/+i8ciQN2IF0D98saL+/v7337/4+XubfPxN4lftLV83qL5+JuXu7dkC6B6xAugftnjxeTr7989e/Gq+fRN/LdV//af5tM3z1684vMWwBNBvADqd6F4cT9PYzx78ap5/rr57Ifm85/WJyZf/Nx8/lPz2Q/N89fPXrxi0gJ4UogXQP0uFy8mv/3+x7c//vJy9/ajL980f/lq+ffRl29e7t5+++MvBAvgqSFeAPW7dLwAAAfxAqgf8QJAYcQL oH7ECwCFES+A+hEvABRGvADqR7wAUBjxAqgf8QJAYcQLoH7ECw CFES+A+hEvABRGvADqR7wAUBjxAqgf8QJAYcQLoH7ECwCFES+A +hEvABRGvADqR7wAUBjxAqgf8QJAYcQLoH7ECwCFES+A+hEvAB RGvADqR7wAUBjxAqgf8QJAYcQLoH7ECwCFES+A+hEvABRGvADq R7wAUBjxAqgf8QJAYcQLoH7ECwCFES+A+hEvABRGvADq96d//vq/AFAQ8QKoH/ECQGHEC6B+xAsAhREvgPoRLwAURrwA6ke8AFAY8QKoH/ECQGHEC6B+xAsAhREvgPoRLwAURrwA6ke8AFAY8QKoH/ECQGHEC6B+xAsAhREvgPoRL4Aymr//Wuu/rU1BvADqR7wAynjwEEC8AFAO8QIoYxqJ//vf/37wwQfV/C/xAoCMeAGUMY3E06hchw8++IB4AUBGvADKWGYvakK8ACAjXgBlM HuxIF4A9SNeAGUwe7EgXgD1I14AZVx29uK7T5aT+sN//Nt49fjTd580zSff5d0msxcAVMQLoIzLzV78+x8fGtnB/GmOF999kj1bTIgXAGTEC6CMi81e/PsfHxoTFtMLxzQxxYtLhQtmLwCoiBdAGZeavVjDhP/Sd580H37ohI+siBcAZMQLoIxLzV7I8WKKFMdPZFwoXzB7AUBFv ADKuNhnL9bPbx4JD0cuNYFBvAAgI14AZVzuN0f8j3bOacL4aOc FAgazFwBUxAugjIt+78W///HhclKrv5h6gYRBvAAgI14AZfCtnQviBVA/4gVQBt/auSBeAPUjXgBlMHuxIF4A9SNeAGUssxdTwqjjf4kXAGTEC6CMa SSu8t/WpiBeAPUjXgBlPHgIIF4AKId4AaAw4gVQP+IFgMKIF0D9iBcAC iNeAPUjXgAojHgB1I94AaAw4gVQP+IFgMKIF0D9iBcACiNeAPU jXgAojHgB1I94AaAw4gVQP+IFgMKIF0D9/vTPX/nHP/7xr/A/90pEvAAAAJkRLwAAQGbECwAAkBnxAgAAZEa8AAAAmREvAABAZs QLAACQ1/8BSmNq/emMPxYAAAAASUVORK5CYIIA" alt=""><br><br>Hopefully everything will work as expected after that.<br><br>/Fredrik
<br>
<br><br>Thanks for your help<br>I managed to get it sorted using the webclient(64bit) and launching the zenwebclientstarter.exe from command prompt with the relevant switches used. Then to allow the activex feature to work I used a modified zenrt32.tlb file...<br>All sorted after months of trying<br>
