Webserver Routing & Redundancy
Hello Team,<br><br>I have a primary and redundant PC. I would be using Webserver upto 20 Concurrent clients. In order to achieve redundancy do I need to procure two licenses of Webserver and install at both servers or can I buy a single license of Webserver and install it on a third PC(routing) and achieve redundancy.<br><br>Kindly advice<br><br>Thank You
Re: Webserver Routing & Redundancy
Hello,<br><br>both scenarios are possible.<br>Depending on if you only want to monitor or also operate through the webclients you will need to purhcase zenon Web Server or zenon Web Server Pro.<br>There is also an explanation in our manual in the section "zenon Web Server", if you have zenon installed.<br><br>Regards,<br>Felix
Quote:
Originally Posted by
felixst
<br><br>Thank You Felix<br><br>
<br>
