Hello Team,<br><br>I am facing a problem in zenon logic. Whenever i am going to project setting am getting a error popup that is "The Parameter is incorrect". Screenshot has been attached. kindly suggest.<br>
Printable View
<strong>! IMPORTANT !</strong><br>The steps I will describe implies to modify project files manually.<br>If you are not 100% sure about what is contained in the project files, do not modify or remove it!<br>Before doing any modifications it is recommended to do a project backup or at least a backup of the related files.<br>-------------------------------------------------------------------------------<br><br><br>Hello,<br><br>It seems that when you try to open the Project Settings, zenon Logic cannot find the appropriate settings page.<br>Does it happen everytime you try to open the Project Settings? Then you cannot access to it even after clicking on "Ok" ?<br><br>By the way if you try to do it while the application is in RUN mode, then the settings are in read-only.<br><br>What you can try is to edit the '__K5DB.INI' file in your project:<br> 1. Click on your project on the left of zenon Logic<br> 2. Press <strong>CTRL+ALT+E</strong> in order to open the folder where the project is<br> 3. Edit the '__K5DB.INI' file<br> -> There should be a '[DBOPTPW]' entry<br> -> Remove this entry*<br><br>The cause could be that in an older version of the project, other Settings were available...<br>Also check that this file is not write protected otherwise zenon Logic will try to access to this unknown page everytime and will not save the new/valid one.<br><br>I hope it helps,<br>Best regards,<br>Anthony<br><br><br>*T<span style="display: inline !important; float: none; background-color: rgb(255, 255, 255); color: rgb(34, 34, 34); font-family: Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif; font-size: 13px; font-size-adjust: none; font-stretch: normal; font-style: normal; font-variant: normal; font-weight: 400; letter-spacing: normal; line-height: normal; orphans: 2; text-align: left; text-decoration: none; text-indent: 0px; text-transform: none; -webkit-text-stroke-width: 0px; white-space: normal; word-spacing: 0px;">he PAGE=x entry Under the [DBOPTPW] section is the tab number in the project settings, so for example if you have 6 pages and PAGE=7, it will fail to access to it</span><br>
